Old 04-17-2014, 07:48 AM
idleup idleup is offline
Default Installation Photos of Z-Drawing Components...
Does anyone have (or know of) photos I can look at of mounting locations for items in the Aeroelectric Z-Drawings? Specifically I am looking for ideas on where to mount the following:
- SD-8 Alternator Voltage Regulator (PMR1C-14)
- Voltage Regulator Capacitor (S8007-1)
- Overvoltage Protection Relay (and how do you mount the crowbar over voltage module? it has no mounting tab/holes/etc???)
- E-Bus Diode heatsink assembly
- E-Bus alt feed relay
Any web links to albums or photos showing these components mounted would be very helpful. Thanks.
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 04-17-2014, 08:19 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I mounted my SD 8 control items on a scrap piece of alum, and then used nutplates and screws to mount the plate to the sub panel. The crowbar is just glued onto the plate with a dab of Shoe goo.
As to the E buss stuff, sorry no help there.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-17-2014, 10:16 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
The OV crowbar is so small and light it can just be ty-raped to a wire bundle -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-02-2014, 08:22 AM
Does anyone have photos of the items below, specifically the mounting of the Capacitor and or the Hall Effect amp transducer from Advanced Flight Systems for using on the backup alternator?
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
