I will start this post by saying there are as many opinions on this subject as there are builders...
Alodine is an excellent corrosion protection surface treatment. It's main weakness is that it is very thin and easily damaged by scratching, abrasion, etc. In applications where the surface is not susceptible to any sort of wear, and the environment is not too hostile, Alodine is acceptable as is. In cases where the Alodine may be compromised, a corrosion resistant coating is recommended. Given your Florida address I would be inclined to Alodine and prime.
