RV-6 Com Antenna Location Suggestions
I currently have a wing tip com antenna that I am replacing with a RAMI AV-17 bent whip on the belly. There is currently only one external monopole transponder antenna mounted directly below my fuel selector, forward of the wing spar. Is there a minimum distance that I need to stay away from the transponder antenna? I am looking for mounting location suggestions and pictures if available.
Chad
RV-6
O-360-A1A
Hartzell CSP
