Old 04-16-2014, 01:17 PM
wrongway john wrongway john is offline
Default Can anyone identify these white rocker switch?
Not original builder, and can’t find a name of manufacturer on these switches. My electronic fuel pump switch is stuck in the on position. It’s lighted. Van’s says they never carried this kind of rocker. Anyone knows who does?
Old 04-16-2014, 01:24 PM
xavierm xavierm is offline
Default I think these are it
GCA (Gulf Coast Avionics) Lighted Rocker Switch
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
Old 04-16-2014, 01:29 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Thumbs up VAF is amazing...
It took Xavier a whole 7 minutes to answer that question and help a fellow RVer....
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 04-16-2014, 01:36 PM
Xavierm, that was quick! And it does look like that is it. Thanks a lot.
Old 04-16-2014, 01:43 PM
az_gila's Avatar
az_gila az_gila is offline
To be a bit more specific -
Honeywell AML switches -
http://www.engravers.net/rocker-switches/aml34-36.pdf
Can be bought in different colors and custom engraved here -
http://www.engravers.net/aircraft/rocker_switches.htm
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-16-2014, 02:06 PM
larosta larosta is offline
Go to DigiKey or Mouser
http://www.digikey.com/
http://www.mouser.com
and do a search for
"Honeywell rocker switch"
You can then drill down from the list of parameters to find a switch that meets your requirements.
Old 04-16-2014, 02:12 PM
Bavafa Bavafa is offline
As Gil said and the best rocker switch in my opinion.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 04-16-2014, 03:35 PM
Don Jones's Avatar
Don Jones Don Jones is offline
http://shop.lancair.com/inventory.as...-B80FF8E89C67}
I got mine here from brand "B" These are made by Eaton
In stock, engraved, lots of choices.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 04-28-2014, 11:57 AM
Thanks for everyone's help. Good to know Honeywell makes these, and various suppliers have it. Went with GCA.
Found out what was wrong with my old switch, and why it was stuck in the on position. Had anyone told me to check the light bulb, I would assume they were making a joke. But that?s what is was. After I took the switch out, I could tell something was rattling inside it. Took it apart and it clearly was my light bulb that had gotten loose, and worked itself into a position to keep my fuel pump in the on position. It works fine now, but put the new one in, anyway.
It didn?t come with the white front face that said ?fuel boost? on it; salesman said just to use my old one. Just used the thick part of a razor and thin screw driver to pry it enough to wedge the razor on one side, and then used the screwdriver again on the other side, and it popped right out of the old one, and just as easily popped in the new one.
