I believe you will need a spacer/washer for the firewall - I did on the 10. The material is too thin for the Nut to contact the surface and snug up on the threads. The washer also helps to spread the load against the thin stainless steel firewall.
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
