Jerry,
I only did my front stick so I can't give you any advice on how to connect or route the rear cable.
For my front stick, I stole my setup from Larry at BowenAero.com. I just checked his site and it doesn't look like he has those pictures in his archives anymore. So I'll post some of my own.
I cut a slot in the lower portion of my stick for the cable exit. I had heard some discussion on the RV-List about this hole weakening the stick, so I tried to keep it to a minimum size. No room for a snap bushing, and you couldn't use one anyway because the cable is too thick to make a 90 deg. bend. And since I wasn't using all of the connections in my Infinity grip, I removed all the wires I could from the bundle to make it as thin as possible. I then packed RTV in the hole where the cable exits to serve as the anti-chafe medium.
For a connector, I got the same Amp plug and receptacle that Larry used from Mouser.com. Stock numbers are: 571-2061521 and 571-2058393. I pondered how I was going to secure the cable and plug as it went from the stick to the gear tower but in the end I just left them lying on the floor. It doesn't seem to want to go anywhere and it is not visible from any angle that you normally look into the cockpit from.
