If I know what someone means, I'm good. Call it what you want as long as it gets done, but make sure you reference your OPS limits and copy the wording in your log book as it is shown there.
I can not answer your gear tower question.
You should have your Hartzell manual in hand. It tells you the grease type, interval, and procedure.
You should also have a good check list. It is ok to start with someone elses but modify it to fit your specific airplane. One of the items on the check list you will find very handy is to add in common torque values for all things that need to be checked or retorqued at your CI. Then you don't need to dig up the manual each year.
My check list continues to grow and get more comprehensive every year.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
