  #11
Old 04-14-2014, 10:28 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
As I recall, I had about the same gap. I believe that the floors help with the shape of the outer skin in that area. Just a little inward pressure on the fuse skin, and mine went right together.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 04-14-2014, 11:41 AM
jwilbur jwilbur is offline
Any oil-canning after it was all riveted together?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 04-14-2014, 12:58 PM
9GT's Avatar
9GT 9GT is offline
Mine were not anywhere near that far off in alignment.
David C.
Howell, MI
Old 04-14-2014, 01:28 PM
Default I wonder why
I wish I could understand why anyone's are off at all. They most definitely were NOT off when I match drilled everything. They must bow outward somehow when the side skin gets riveted on. What else might cause this?
Also, to get the clecos in I have to push pretty hard on the side. I'm wondering if it makes sense to add a few more rivets to the floor/channel to increase the strength of that connection. Any thoughts on this idea?
Phase II - 11/2017
RV-10 Build Log
Old 04-14-2014, 01:40 PM
Fracrat Fracrat is offline
Default I'm at this point now.
I believe the landing gear weldments are installed just prior to this. Could that have something to do with it? I know my weldments are going to have to be flexed inorder to get them in.
Gordon(Gordo) Fowlkes
Old 04-14-2014, 01:52 PM
That's not it. The gear weldments are installed after the floors. One segment of the weldment, in fact, sits on top of the floor. Good thought, though.
Phase II - 11/2017
RV-10 Build Log
Old 04-14-2014, 02:23 PM
paul330 paul330 is offline
I remember it took a lot of "easing" to get the rivets in. The problem is that the fuselage angle that you rivet to is slightly angled away. Basically, I had to put a cleco through whichever floor hole looked the closest and then guide it into the longeron and then push up to get it in place. Once you have one in, the others are easier.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 04-15-2014, 12:14 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
I noticed that when I did my first inspection and took off the top floor panels it was very difficult to put the outboard screws back in. The trick was to install the outboard fasteners first and work toward the middle of the plane. I don't know why this went together easier but the center holes lined up perfectly using this method. Perhaps it will work the same way when attaching the riveted area of the floor. Might be worth a try.
Old 04-15-2014, 01:22 PM
dspender dspender is offline
Can you describe oil canning? I am just installing the side skins and longerons so not to this step yet.
Dennis
Old 04-15-2014, 01:28 PM
Imagine the sound you hear when you squeeze one of those old-style metal oil cans when empty. In this case my front side skins are all riveted to the skeleton but when I cleco on the floors in place (in my case) it results in an ever-so-slight "deformity" or bubble in the skin so that I can press on the skin in that spot and cause this bubble to jump to another spot with a little "ka-chunk" sound.
Phase II - 11/2017
RV-10 Build Log
