Old 04-11-2014, 10:49 AM
Default Growing Pains-----
I just wanted to take a second and keep everyone up to date on a couple of things.
First--Sad and Excited to say that we are experiencing growing pains. WE have had some vendor issues on hose ends, where we have not only run out, but They have run out also. Great problem to have is that we are busy, and business is really good. Bad problem is that we have been delayed in getting some orders out. Finally getting caught up. Our fitting vendor has doubled his production, so hopefully we can anticipate our needs alittle bit better. WE thank all our you for your business, and your patience while we get situated!
Second--We have several new kit packages in the works now, not only for the RV12' s but the 7/9's, and the 10's as well. Some of those new packages have been tested by some of you, and some pictures have been posted. Some have not, but will be soon.
For you guys and gals that 'like' to fly inverted, we are working on 2 different flop tube configurations, with teflon. This should be a major step forward. Also, a new type of flexible teflon hose for inverted oil systems has been under development for a while now, and after make a few changes, we have our fitting vendor gearing up to produce the fittings we want. Yep---we're behind, but we want to make it right.
Again---we appreciate your business, and we hope to have these growing pains under control.
Tom
Ridgeland, SC
Old 04-11-2014, 10:52 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Congratulations!!
Tom, congrats on the "Growing Pains"
Shows that you are doing things right.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
