Old 04-03-2005, 10:51 PM
ksouthar ksouthar is offline
Default James Cowling and Plenum for RV-9A
I am ready to begin fitting a cowling and have been looking at the James Cowling for my RV9A.
Anyone have experience with them and in particular the RV9 version?
Keith Southard
n162@hotmail.com
Old 04-05-2005, 07:40 PM
N62XS N62XS is offline
Default Rv-8
Fitting the Cowlis straight forward, but you will need an extended hub prop. Sam says to use a 4" prop extension, but everyone I talked to did not recommend any type of extension with a CS prop. I'm using a WW151 extended.
The plenum is another story. Calling it a PITA is being kind. One bit of advice, use Van's baffling kit. It will save you time. I was fortunate to benefit from Dave Hamilton's experience on an IO-360A1B. I visited his RV-8 and snapped over 60 digital photos. Even with these reference shots, the fit required a lot of cutting, reglassing and sweat.
I would do the cowl with no question, but the plenum would be copied from a website that uses Van's baffle kit and a fabricated aluminum top.
Robby Knox
Old 04-06-2005, 12:54 AM
jclark jclark is offline
Default Will James has a cowl that might fit without problems ...
Please note that if you are talking about using the cowl for a carbureted engine,
**Will** James now has a cowl that is about the same dimension as the standard Van's cowl but with the circular inlets (3 of them).
James
Robby Knox
