No gasket
I received no gasket, but there is an o-ring at the base that seals the base where the antenna connects. I don't think the antenna requires a full size gasket.
Mine has started to give me trouble, on Garmin rep on here seems to feel tightening the base screws can cause damage to the antenna over time. Install manual had no torque value when I installed mine so check to see if it is published now.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
