Old 04-06-2014, 07:41 PM
idleup idleup is offline
Question Mounting the Lightspeed Plasma control unit...
Is the way I mounted this okay or does it need a backplate? The rib is kind of flimsy and thin metal...
https://flic.kr/p/mR3qer
http://flic.kr/p/mR52nm
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 04-07-2014, 06:38 AM
Scott Hersha Scott Hersha is offline
Looks fine to me Matt. The metal angle that is part of the Plasma unit itself adds stiffness to web of that rib. Once you get the top skin riveted in place that rib should become quite solid.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 04-07-2014, 06:48 AM
Walt's Avatar
Walt Walt is offline
Agree, you'll be just fine like it is.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-07-2014, 08:11 AM
flion's Avatar
flion flion is offline
However, while you still have access, think about how you will get to it to work on it. Getting a screwdriver up there once it's closed up and there are wires and stuff in the way is a nightmare. Ask me how I know. On the -10, I thought about my experience and so I used some aluminum angle to fabricate a couple of capture rails. The upper end has rivets that limit how far the unit can slide into the rails and the unit is held in place with two screws at the bottom in nutplates. The hardest thing to reach in my installation is the DB connectors because they are so close to the subpanel. The coax connectors are not too bad, and the two screws are a breeze, dropping the unit down onto the rudder pedal assembly (with a little relief in the rails so I can get the unit all the way out). In your case, you'd need to make a stand-off so the unit could slide downward past the rib flange. Sorry, I don't have a great picture of mine online right now but a little planning now will make servicing later a whole lot easier.
EAA Technical Counselor #5357
Old 04-07-2014, 08:35 AM
Kahuna's Avatar
Kahuna Kahuna is offline
+1. That will work just fine.
Kahuna
6A, S8 ,
Gold Hill, NC25
