Go Back   VAF Forums > Main > Safety
Old 04-04-2014, 09:58 PM
Sonex 541 Sonex 541 is offline
Question Smoke on for safety ??
Well flying a fully polished airplane can be near invisible in the sky so I hear , while flying into my local class D airport I was number 2 on final and there was a cirrus on the downwind , he was goin back and forth with the tower trying to locate me , and kept saying he couldn't see me , would it be acceptable to turn the smoke on for a few seconds to make myself visible , I was so tempted to turn it on but wasn't sure if this was the right thing to do while on final , I have had this issue before of not being seen in the traffic pattern , and has anyone else had this issue and turn the smoke on ,
Btw I had my led nav and strobes on the entire time .
Adam S
Old 04-05-2014, 01:29 AM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
Adam
I would have no hesitation giving a quick burst of mine (primary reason why I fitted it). When I approach an intensive area of activity I switch it to standby ready for such an event.
Bob Ellis
www.rv-8.co.uk
G-JBTR Having a ball flying this wonderful machine
Donation July 2016
Old 04-05-2014, 05:58 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Absolutely! Have done this dozens of times. Kind of fun at home field when Ellington calls me out to other traffic and I can lay out a couple of streams of smoke for them. I've never not been seen.
Old 04-05-2014, 08:24 AM
Toobuilder's Avatar
How much smoke are you going to make with the throttle pulled back to idle (on final)?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 04-05-2014, 10:29 AM
Snowflake's Avatar
You've heard of TCAS? Well, smoke is VCAS... Visual Collision Avoidance System.
If someone can't see me in the circuit, I would do anything possible to become visible. Right now, that's rolling into knife-edge and out again. When I get smoke, it'll be with smoke.
I wonder if a small circuit to pulse the smoke at regular intervals, making a dotted line, would be useful... Turn it on as you join the circuit, turn off after touchdown. It wouldn't have to use very much smoke oil, just a short pulse every 10 seconds maybe?
Rob Prior
Old 04-05-2014, 11:41 AM
WenEng WenEng is offline
Default In the interest of safety....
And this, my friends is precisely why my wife readily approved the expense for Marvin's smoke system. She's so great!!, and appreciates my concern for safe flight
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 04-06-2014, 06:53 AM
GeneL's Avatar
GeneL GeneL is offline
Default Smoke
Don't leave your smoke on at idle on the ground it can cause a fire! Some systems even require a switch on the throttle. If you have it on while on final you could forget it.
I have used my smoke going into Oshkosh after the AV Cup Race, semi mass arrival controller couldn't figure out which flight of three we were, 2 seconds of smoke and he said "thanks".
Old 04-07-2014, 07:06 AM
I've thought of installing a smoke system precisely for this reason.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 04-07-2014, 07:51 AM
DaleB's Avatar
DaleB DaleB is offline
I had never thought about installing one... but now I am. Yeah, safety, that's it. That's the ticket.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-07-2014, 01:07 PM
erikpmort's Avatar
erikpmort erikpmort is offline
Any chance the plane behind would have any visibility issues if he flew direct in your flight path ? I'm thinking no but wanted to be courteous of others. I think it would dissipate plenty fast
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
