Old 04-02-2014, 03:16 PM
jdeas's Avatar
jdeas jdeas is offline
Default Control cable seals
This control cable is less than two years old and I have only been flying 30 hrs! Has anyone else seen this with Van's cables? I know LA smog is hard on rubber but
This is the worst one but all three cables have cracked boots.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 04-02-2014, 03:45 PM
flyboy1963's Avatar
Default DITTO
Mine are the same after 60+ hours, apparently they are neither heat nor oil resistant!
Zip tied mine on for a while, then it just disinterieted, dissingretated, dissgrint....
fell off!
Pushrod seems to still work....I suppose it may wipe some of the grime off the rod.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 04-02-2014, 04:09 PM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Do you know what make of cable it is ???
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 04-02-2014, 04:28 PM
rzbill's Avatar
rzbill rzbill is offline
They are ACS. Replacement seals are available from Spruce. Common problem. I covered mine with some firesleeve.
I'll post part numbers when I get home.
EDIT*** The big one in the OPs picture is part #05-02633. The smaller one closer to the end of the cable at the left is # 05-02634.
Like the fellows below said, the new ones are blue. *****
Bill Pendergrass
ME/AE '82
Old 04-02-2014, 04:39 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Just got a set of replacements from ACS. The new ones are blue and appear more substantial than the black from Van's. I think a couple of the black ones tore during installation. Away from home, otherwise would give the part numbers.
Dave
M20C
Old 04-02-2014, 05:10 PM
BillC BillC is offline
I had the same problem and purchased replacements from ACS. I have found that rubbing DC#4 (same stuff recommended for application to your oil filter rubber seal) into the seals during my annual condition inspections has works well in prolonging the problem seals' life. Have about 4 years on current set. Also use same stuff on elevator trim cable seal.
YMMV
Bill
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 04-03-2014, 11:27 AM
jdeas's Avatar
Thanks! new seals ordered!
JD
RV-7 N314SY (KWHP)
IO-360-B1B
