Don, well you could, and bond each one at one end. That would not be a really good installation though, more weight , more connections to come loose more wires to chaff etc. on my ztron I used 3c shielded. I actually need a fourth wire for the synch in between each wing lights. I ran the synch wire separate without a shield,it is a signal and doesn't carry any led noise. Drop me a note if you have any more questions.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
