Old 09-20-2006, 12:11 PM
PaulR PaulR is offline
Default Wing Assembly Question
I'm looking for opinions about building the wings, both at the same time. I have plenty of room, so that's not the question. I've gotten both main and rear spars already complete along with all the ribs. I've assembled the left ribs and spars and was getting ready to put it on the stand and really think that building them both at once would be beneficial. Then after sleeping on it, thought that maybe some pitfalls could be avoided in the second wing, after learning on the first one.
All opinions are appreciated.
Paul Rose
RV-9A Wings
#91300
Old 09-20-2006, 12:21 PM
Righty Righty is offline
Paul,
I'm about at the same stage as you and have decided to go with both at the same time. Not sure if this is best, but it seems more efficient in terms of a manufacturing process.
Aaron Frechette
RV9A Standard Kit (wings)
Old 09-20-2006, 12:31 PM
Wes Hays's Avatar
Wes Hays Wes Hays is offline
I built my wings one at a time on my -6. I am working on the wings now for a -7 and am building them both at the same time. I really believe it is faster in the long run to do them both at the same time. I tended to forget from one wing to the other, and had to go back and review the plans a lot.
By doing them both at the same time, you get all the work done for both wings at the same time and it really seemed to go faster. (The pre-punched wings are amazing. I can't believe the fit.)
FWIW
Wes
Old 10-12-2006, 06:58 AM
milt milt is offline
We, my son and I, are going to do both at the same time. Spacing the jigs far enough apart that we can work in between them. But, hey, what do I know. I am 2 years from retirement and got hooked on this project with my youngest son who is an aircraft mechanic for corporate business jets in the local Dallas area ... I just pay the bills!
Milt Atkinson
RV 8 Dad
N218HM Reserved
Emp Done!, Wings Done!,Working on fuse!
Old 10-12-2006, 07:45 AM
RV7ator RV7ator is offline
You can build two simultaneously, but it still takes twice the assembly effort of one, and there's no reducing initial noodling time. The instructions aren't perfect, BTW; don't get lead down the garden path twice. Meanwhile, you've squashed your learning curve, the principal benefit of one-at-a-time being that you may want to deviate from the plans on the second wing for reasons of modification, access, tools available, and avoid making the same mistake twice. You WILL see things you'd do differently after having built one wing.
Fabricating all components when tool set-ups are involved does save a bit of time, provided you get it right from the get-go, often only apparent at installation. But such savings are overwhelmed by the amount of time translating instructions/plans into action, so it's not a biggie.
The second wing will go together amazingly quickly. As a percentage of the airframe, the wings yield the largest chunks for the least effort, so I do not believe it is a wise choice hoping to beat the clock while limiting learning.
John Siebold
-7 and (lighter, more hp) -7
Old 10-12-2006, 07:47 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Same time is no question more efficient. You will have some brain teasers on lefts and rights, but you will work it out. Imagine if you were building 10 wings. Much better to do at the same time.
Best,
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 10-12-2006, 08:46 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default Build them both at the same time
I just finished my 8 wings last week. I am glad that I did them both at the same time. I would accomplish each major stage on one wing and then do the same thing with the other. For example, I drilled the skins on the left wing and then did the same on the right. Then, I would debur, scuff, dimple and prime the skins for each wing. Believe it or not, if there were several months between the wings, you would probably forget how you solved each construction problem on the first wing. I agree with everyone else. Build them both at the same time.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 10-12-2006, 10:20 AM
Default Both It is.
Since my original post, I mounted both stands to the floor and proceeded. I'm really glad I did. The only part that's at all annoying is deburring the skins for one, only to turn around and have to do the other one. That's probably my least enjoyed task of this whole build process. I have to stay really focused to get it done. Anyway, after figuring out the first leading edge, the second almost fell together. The only pitfall I've run into is with clecoes. Obviously the tool guys only put in the kits what's recommended but if you're doing both at once, you'll need at least a couple hundred more clecoes. That being said, I would still do it again this way.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 10-12-2006, 03:26 PM
LOCKNUT LOCKNUT is offline
Same time is the only way!
Old 10-13-2006, 12:47 AM
N674P N674P is offline
Aint that the truth - I've got at least 500 silver (3/32") clecoes, and still felt I was short. I riveted both leading edge skins to thier ribs to free a bunch up, and believe I have enough now to carry me through.
Johnny Pruett
VAF #601
-9 fuselage standard kit on hand
Slooow build wings still in progress...
