Old 03-27-2014, 01:58 PM
AcroSmoke's Avatar
AcroSmoke AcroSmoke is offline
Default Another proseal question
I haven't closed up my tank and the proseal on the ribs and stiffeners has cured. I want to add some extra proseal to rivets and ribs just to make sure they are less likely to leak, will it stick ok or do I need to do some prep work?
Thanks in advance.
David Otero
David "Stogie" Otero
Albuquerque, New Mexico KAEG
Owner:BladeSox, LLC . www.BladeSox.com
Member of Chile Flight
EAA Tech Councilor
Finished RV-7 12/30/15
N505RV
Segundo Viento
Paid my 2020 dues, you should too.
Old 03-27-2014, 02:10 PM
Ron B. Ron B. is offline
I would say you are fine as is.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 03-27-2014, 04:45 PM
g zero g zero is offline
Default Sealant
Have you seen his tanks ? Probably not .
I do believe the sealant will stick to the previous applied sealant just fine . If you think it needs more add it now as it is easy to do .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 03-27-2014, 04:55 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Pretty sure that's what Ron was trying to say.....
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 03-27-2014, 05:00 PM
scard's Avatar
scard scard is offline
Wait a minute, you just spent some quality time with Proseal, and you're asking if it will stick... . You know the answer. Of course it will.
Scott Card
CMW E-Lift
Old 03-28-2014, 06:25 PM
DaveWelch DaveWelch is offline
Default sticky stuff
I've seen a blob of ProSeal leap halfway across the room just so it could stick on something I'm trying to keep clean. No worries!
Old 03-28-2014, 07:00 PM
"Fine as is", ie no prep work needed before applying more Proseal, which was the answer to OP original question.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
