Old 03-26-2014, 10:10 AM
MartySantic's Avatar
MartySantic MartySantic is offline
Default Moving the Oil Cooler Forward 1" - High Oil Tenmperatures
Just completed the process of moving the cooler. Thought I would post a link for those contemplating the same.
Here is a link to my photos and the info I collected from five others that did it before me. My thanks to all that helped me..... Dave Farmer, Pete Anderson, Bob Kibby, Torsten Leibold and John Albury.
Will paint and then will be awaiting the 95 degF days... 20 degF this morning, will they be back?
https://www.dropbox.com/sh/oh6xzctv990v2ed/Mbp73pOI-F
Will keep the link active for a few months. If it fails to work send me a PM via my VAF mailbox.
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 03-26-2014, 10:45 AM
DHeal DHeal is offline
Were your original Van's-supplied oil cooler hoses sufficiently long enough to attach to the relocated cooler?
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
Old 03-26-2014, 11:53 AM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default Very helpful set of pics.
I'm just starting the mod process, and your pics answer several questions for me. Looks like you were able the bust part of the fiberglass flange apart from the lower cowling, rather than cutting the flange off. I'll be giving that a try...
Rob Reese
RV-12 #120332 N73HR
Austin, TX
TangoFlight Mentor
Old 03-26-2014, 12:11 PM
I installed the thermostat and one of the hoses is not original. Others with the stock hoses have found the hose length to be sufficient.
Davenport, IA
Old 03-28-2014, 06:29 AM
Peterk Peterk is offline
Nice job Marty. I should have had you do mine.
Old 03-28-2014, 11:44 AM
RGaines RGaines is offline
Default Oil cooler
I moved the oil cooler forward an inch on the previous condition inspection (1 1/2 years ago). It helped a lot. Probably solved about 90% of the hot oil problem. During hot weather we can still run into the yellow now but nothing like before.
Rich
Old 03-29-2014, 08:07 PM
yankee-flyer yankee-flyer is offline
Default My results are about like David's.
Often in the yellow arc before the mod, now once in a while and drops out of it when I come back to cruise power. Original hoses are long enough-- barely! It's more of a hassle to get the lower cowling back on than before.
Wayne 120241/143M
