Old 03-25-2014, 05:57 PM
aeroaddict's Avatar
aeroaddict aeroaddict is offline
Default Fuel Return for Injected Engines?
Just started to build the fuel tanks and stumbled across a post about the fuel return lines needed for fuel injected engines. I haven't really thought that far forward but plan on using a common experimental (ex-certified) engine with fuel injection. A brief search did not reveal much info.
Is it common for injected engines to have a return?
Old 03-25-2014, 06:02 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Some do, some dont.
If you install a bung fitting, it can be plugged if you end up not needing it.
Airflow Perf uses a return line, but it is manually controlled, used to shut off the engine, and to purge the hot fuel from the system for restarting a hot engine.
Some Electronic Fuel Injection systems may use a continuous return, as do some mechanical systems.
What kind of injection do you plan to use??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-25-2014, 06:24 PM
sirlegin's Avatar
sirlegin sirlegin is offline
We had the fuel lines plumbed for a return but were told by an expert that it wasn't necessary. Been flying for 300 hours without it and have no problems what so ever.
Nigel
RV9A-N113SQ
52F
Old 03-25-2014, 06:28 PM
aeroaddict's Avatar
Well that is the issue, I really haven't investigated the whole engine choices yet. So I guess I need to do some homework before completing this tank.
The other part of the story is that I was able to pick up a decent quality partially built wing kit and one tank is already built and without a return line.
Another question would be, if a return line is needed, can a retro fit be done on a completed tank?
Old 03-25-2014, 06:45 PM
jrs14855 jrs14855 is offline
Default Fuel Return
Except for the optional purge valve system, Lycoming engines do not require a fuel return line. Continental injected engines and some with carburetors such as the Bendix PS5 all require return lines.
Old 03-25-2014, 06:46 PM
Mike S's Avatar
Senior Curmudgeon
Yes, not hard at all.
I had to do that on my 10. You just work through the fuel sender hole, before installing the sender.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 03-25-2014, 06:51 PM
aeroaddict's Avatar
Well, that settles it; Lycoming it is!
Old 03-25-2014, 06:54 PM
erich weaver's Avatar
Return line doesn't necessarily have to go to the tank itself. On my AFP system, a purge line tees back into flow line from right tank. When purging, I just make sure tank selector is set to the left tank so I am pulling cool fuel through the system instead of just recirculating hot fuel.
Erich
Old 03-25-2014, 09:07 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
ECI fuel injection systems for Lycoming absolutely require return line plumbing, and it must be plumbed thru a duplex fuel valve to go back into the same tank you're feeding from. The large volume of excess return flow is utilized by the high pressure pump to help cool itself.
Neal Howard
Airplaneless once again...
Old 03-25-2014, 09:21 PM
SHIPCHIEF SHIPCHIEF is offline
It is so easy to install it early in the construction process, I say Do It!
Later, if you upgrade to a system that needs it, the effort will be nil and you will be grateful you put in the small effort now.
You will need this if you use a modern automotive based fuel injection system, like EFII or SDS.
I did it, I love it.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
