Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #61
Old 03-25-2014, 07:12 PM
grayforge's Avatar
grayforge grayforge is offline
Originally Posted by N411TW View Post
Steve-
My question is can I swap out my GDU 370 PFD for a touch? Would it fit? Would it have compatibility? What adjustments need to be made? Thoughts? Thanks!
-Tim
Tim, a side question: What exact model of switches do you have in your panel? They're nice and compact.
Thanks!
Russ
Speed Is Life
VAF Donation made: 1/28/2020, My RV-7A Build Log
Old 03-25-2014, 07:53 PM
SteinAir SteinAir is offline
Those would be the Honeywell AML switches. A bit pricey, but very high quality with a completely separate circuit for lighting. The covers are labeled/engraved, and they can be mixed/matched with the LED bulbs for some nice dimmable results. They are our preferred rockers....
Stein
Old 03-25-2014, 08:58 PM
rsipp rsipp is offline
Congratulations Steve, a great announcement.
Would a Freeflight 1201 WAAS sensor be compatible with the G3X Touch and would the display advise which GPS approach is valid?
Dick Sipp
Old 03-26-2014, 04:56 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Dick Sipp
Hello Dick,
Thank you.
I am not familiar with the 1201, but I looked at an online datasheet and it doesn't look like it is anything but a WAAS GPS receiver. It is not an IFR navigator, so no, installing this would not provide any GPS approach capability.
Just a reminder that the GDU 460/465 have excellent VFR WAAS GPS receivers built into each display.
We extended our $3,995 special on the GPS 400W IFR navigator into 2014 (purchased with/for a G3X system). With this IFR navigator, not only can you legally fly enroute IFR and thousands of autopilot coupled precision and non-precision WAAS IFR approaches, but connecting the ADS-B out interface from the GSP 400W to your GTX 23ES 1090ES transponder provides a FAR 91.227 compliant position source that makes the ADS-B Out from your G3X Touch system compliant with the 2020 requirements.
We have all the bases covered with our fully integrated system.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-26-2014, 06:39 AM
N411TW's Avatar
N411TW N411TW is offline
Thanks Steve, that's very helpful.
Old 03-26-2014, 01:12 PM
rpellicciotti rpellicciotti is offline
Default Looking forward to templates
I'm just in the middle of planning a G3X upgrade to a 1990's six pack panel. I'll be anxious to see the templates for the G3X touch and figure out whether I can fit two of them in my panel.
Rick Pellicciotti
Falco N63KC, KJ4NWQ
Old 03-26-2014, 03:29 PM
N411TW's Avatar
Thanks!
Russ
Russ-
Their Honeywell AML54 rockers and I had the operators engraved here http://engravers.net/aircraft/rocker_switches.htm with the OFF on the top surface. Thanks!
-Tim
Old 03-27-2014, 06:00 AM
g3xpert's Avatar
Post Touch Screen Camera Control
Some have asked for additional information regarding camera control.
I updated the original posting this morning to show this image that shows the "Photo Taken" message that pops up after you touch the "take a picture" button on the right.
You can take a picture that is stored to the VIRB camera SD card at any time, even when recording a video. During video recording, a timer is shown in the camera control area between the buttons to indicate how long you have been recording.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 03-27-2014, 07:33 AM
tomhanaway tomhanaway is offline
Default AOA displayed on screen
Steve,
Can the aoa be displayed in the screen (like the afs units)as opposed to using the stand alone garmin aoa display?
Tom Hanaway
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
Old 03-27-2014, 07:56 AM
rgmwa rgmwa is offline
I think the advances in new technology are great, but can't help wondering when they will make the old fashioned VFR windscreen obsolete?
rgmwa
RV-12LR 912ULS
120346
