Old 03-20-2014, 06:26 AM
Geico266's Avatar
Geico266 Geico266 is offline
Default Air /Oil Separator Update
There was a thread started in 2009 (see link below) about air / oil separators. Any PIREPS or updates on newer models? Which ones would best?
http://www.vansairforce.com/communit...+oil+seperator
Airwolf seems to be Vic's favorite. Any other ones measure up?
Anyone use the ASA Separator?
http://www.antisplataero.com/The_ASA_Oil_Seperator.html
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-20-2014, 09:27 AM
Gash's Avatar
Gash Gash is offline
I installed the ASA separator about 180 hours ago and have been very pleased with it. My belly is dry as a bone.
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
Old 03-20-2014, 09:39 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I installed the ASA complete unit on our Rv10 around 75 hours ago. No oil on belly whatsoever, oil consumption dropped from 1 qt. every 10 hours to 1qt every 16 hours.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 03-20-2014, 05:05 PM
Larco's Avatar
Larco Larco is offline
I just today installed an ASA seperator and the product looks nice. It took me a half a day of screwing around but happy with the install. :-) I did not order the install kit and glad because the mounting location will vary on our firewalls. Mine went on the left side but if you knew the hose lengths in advance it would probably be ok. In my case the return hose would been way to short. Larry
Old 03-20-2014, 07:50 PM
Jgibson Jgibson is offline
Default Just Installed ASA Oil Separator
Just installed ASA oil separator and purge valve system today. Installation went as smoothly as Allen said it would EXCEPT for the pipe plug removal in the accessory case of the motor. Other than that, great product, easy install, looks killer. Oil drainback line 'could' have been about an inch longer but was still adequate for installation in suggested place next to brake reservoir. Thanks Allen for a reasonably priced solution to a p.i.a. problem. Can't wait to get my modified wheel, spacers, and balanced tire assembly.
Old 03-20-2014, 08:55 PM
N941WR's Avatar
N941WR N941WR is offline
One major problem with the ASA air-oil separator is that Allan designed it for his RV-9A, which has its battery in a non-standard location. Thus, his separator is designed to be installed directly above the battery on the right side of the firewall. This location will make future battery maintenance a challenge one side-by-side RV-7's and -9's.
My installation took 10 hours but after 7 hours of flying there is no oil on the belly.
There should be a full write-up in a future issue of KitPlanes so subscribe now.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-21-2014, 11:57 AM
Smilin' Jack Smilin' Jack is offline
I have the airwolf air oil separator the small one have it mounted high on the firewall and it has keep my belly clean
I know some do not recommend air oil separator but there are thousands of them flying with no issues.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 03-22-2014, 07:15 AM
Geico266's Avatar
Thanks to all who have replied.
Okay, I'm not awake yet and I have a dumb question about the "purge or vacuum valve" that comes as an option with the ASA separator. What does it attach to in order to pull a vacuum on the crankcase?
Old 03-22-2014, 08:11 AM
flightlogic's Avatar
You drill a 5/8 hole in the exhaust pipe. Then clamp the outlet pipe to it. The angle of the cut in the path of escaping exhaust draws down the pressure in pulses. The valve makes it a one way process. Oil burns up as well, keeping the underside of the plane cleaner. I put it on for this reason alone. I won't waste my time in the HP debate. A clean plane is a thing of wonder. It is already fast enough.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 03-22-2014, 09:11 AM
Geico266's Avatar
So the exhaust of the engine blow by is vented into the exhaust, the one way valve pulls a small vacuum.... got it.
Thanks! I'm awake now!
