Old 03-18-2014, 09:24 PM
eehite eehite is offline
Default Max Alternator Output
My Nippondenso 60A alternator is currently putting out 14.6-14.7V, but not fluctuating or doing anything else weird. The plane has been down for a couple of months for an avionics upgrade, and these numbers caught my eye because I was used to seeing 14.4V
Is there a good rule of thumb for max acceptable alternator output voltage before I should start troubleshooting?
Thanks!
RV-8A
Old 03-19-2014, 04:10 AM
AltonD's Avatar
AltonD AltonD is offline
What is your battery voltage after the plane has set overnight?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 03-19-2014, 04:16 AM
Tbone's Avatar
Tbone Tbone is offline
Default Voltage
Generally the alt would charge at a higher voltage if the battery was in a discharged state (due to a long hiatus). Top off the charge and it should settle down to normal.....
___________
Terry
RV7
XP IO360
Old 03-19-2014, 05:14 AM
MarkW's Avatar
MarkW MarkW is offline
Default If you have an Odyssey Battery
Odyssey batteries would like to see their batteries charged at 14.7v.
Mine has been charging 14.6-14,7v since new.
I think the Odyssey will last longer being properly charged like this.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 03-19-2014, 07:08 AM
RVDan RVDan is offline
14.5 to 14.7 is pretty common for the Pb VSLA type batteries. I use 14.8 as my yellow line and 15.0 as redline. If you follow the flooded cell battery recommendations they are a bit lower- around 14.2 to 14.5 depending on temperature.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 03-19-2014, 08:58 AM
It's a 12V Concorde battery, but I can't remember the part number off the top of my nugget. I'll check this evening and update this post.
The plane has been mostly idle for a couple of months, with the battery sitting on the Concorde-recommended BatteryMINDer trickle charger.
RV-8A
