Old 09-19-2006, 03:55 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Where to locate OAT probe?
I thought I saw a thread on this a while back, but searching OAT and O.A.T. and "Outside Air" is coming up with zero matches. I located mine inside the NACA vent before I read that it will give high readings. What does the group's collected wisdom suggest? Thanks.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 09-19-2006, 04:32 PM
Tandem46's Avatar
Tandem46 Tandem46 is offline
I have mine (dynon) sticking out of the aft fuselage below the right horizontal stab. This does three things, keeps it away from engine heat, keeps it out of the sun, keeps it from getting broke off when someone tries to brush by it.
RV-7 Flying since 2004
1,100 hrs+
Old 09-19-2006, 04:47 PM
Mel's Avatar
Mel Mel is offline
That's where mine is too. No problems.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-19-2006, 05:21 PM
Scott Will's Avatar
Scott Will Scott Will is offline
Have the GRT system. Mine's in the first inspection panel on the right wing. Fits right inside a snap bushing. Forget what size, though.
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 09-19-2006, 05:52 PM
Rick6a's Avatar
Rick6a Rick6a is offline
I originally located the OAT probe deep inside the NACA vent and the only time the readings were accurate was when the airframe temperature matched the ambient temperature. Upon start up and in flight, the readings were always much higher than the actual OAT.
I relocated the probe as shown above and now the readings are relied upon as accurate. When the access cover is removed, a modest service loop in the cable allows the cover to be displaced more than enough to conduct normal inspection chores. The relocation effort was a simple affair given the location of the digital OAT gauge. A toggle on it allows the choice between a Celsius or Fahrenheit display.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 09-20-2006, 04:02 PM
hevansrv7a's Avatar
Default Thanks to everyone
All were excellent suggestions. I used Scott's because it was easier for me to do and seemed more likely to get the sensor away from any possibility of warmed air from the engine. Thank you all for contributing. I installed it this morning. The snap bushing is a perfect, tight fit, making installation very easy.
