Is this what you're talking about?
Well, you can see that I missed the note on the drawing about installing this fitting before mounting the engine. On mine there are two places you can mount the restrictor fitting. The one on the right is the one called for in the plans. The one on the left (facing directly aft) is the one I'm planning on using. My current plan is to use a straight restrictor fitting from Wicks.
