03-16-2014, 02:26 PM
Proseal shop heads
Question
I'm using Rick's Faying surface method to assemble the tanks.
so far it's going well. I'm ready to rivet the inboard and outboard ribs now and have a question.
Did anyone encapsulate the shop heads on the inboard, outboard and baffle rivets?
They are not inside the tank but could possibly weep if fuel got past the fillet.
Other than a bit more weight I can't see any harm in sealing them.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
03-16-2014, 03:08 PM
Yup!
I covered every rivet in the tank and the entire rib. I also encapsulated the entire baffle flange on the outside. I probably went over board, but I don't have any leaks!
http://www.mykitlog.com/users/displa...=150440&row=49
Don
03-16-2014, 03:18 PM
I covered every single shop head, inside and out. Figured it wouldn't hurt, and it only takes a couple minutes. Just be sure to put down some wax paper on your spar and set the tank into position when the sealant is still somewhat pliable--you don't want it interfering with the beams!
First three tanks have passed the water manometer leak check; fourth tank will (finally!) be getting the baffle soon.
RV-7ER - finishing kit and systems installation
Agreed. I may lose a gallon of capacity to extra pro-seal, but I'll be damned if it'll leak. Passed all the leak tests, so I'm pretty hopeful....
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
03-16-2014, 03:48 PM
Originally Posted by wirejock
Question
No harm sealing them but you can lay down a nice fillet seal inside so there should be absolutely no way it should leak from the rivets.
You must seal the shop heads inside so fuel can't leak down thru the rivet shank, different leak path than the external rivets.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-16-2014, 05:48 PM
Comments
Thanks everyone. Proseal everywhere it is!
Larry Larson
Estes Park, CO
Disclaimer
03-16-2014, 05:55 PM
You know you can't go wrong when 2 ramblin' wrecks agree...go jackets!
Chris Johnson
