This is not a new topic here on the forum. Perhaps this thread will add to what's already out there.
My RV-4 experienced in flight fuel pressure fluctuations. From reading the forum and talking to Van's techs it seems I'm not alone. The typical occurrence was a drop in fuel pressure to about 1.5 - 2 psi when in a climb with the boost pump off. Activating the boost pump ALWAYS fixed the issue. Occasionally the pressure would drop in level flight. Van's described the occurrence as fairly common, not entirely understood, and maybe nothing to worry about. That is probably reasonable advice. Finally in level flight I experienced a fuel psi near zero, my EGT rose and I experienced engine roughness (from an excessively lean mixture I assume). I wasn't sure the engine would continue running without intervention. Pushing the mixture in probably would have helped, but I just turned on the electric boost pump and it immediately gave me 5 psi and all was fine, except it made me think maybe I needed a SPARE electric boost pump since it seemed an electric boost pump failure could at times lead to a forced landing....
So, I no longer was of the "probably not really a problem" mindset and began to consider the problem again. I have numerous pieces of construction equipment that use the same facet electric fuel pump as on my RV-4. Anytime this pump fails (usually due to electrical problems, circuit breaker, etc. - I've never actually had the pump physically fail) my equipment will not run very well or for very long, even with an engine mounted mechanical fuel pump. I attributed this to internal resistance in the pump, since it has no internal bypass. Incidentally, from blowing into a couple of new and used pumps I found the newer the pump, the higher the internal resistance. I did not "quantify" this resistance with any gauge, but just what it seemed from blowing through them.
I installed a check valve (Andair valve from Vans) parallel to my electric pump to provide a fuel bypass so fuel did not have to flow through the pump when the pump was turned off. Schematically this is very simple. In actuality it was a bit tricky due to the limited space (especially the proximity of the pump to the fuel valve) in my RV-4. I used a couple "uncommon" aeroquip aluminum fittings that had to be special ordered and moved the electric pump about 8" aft of its original location, but it all worked out well in the end.
I've only flown about 25 hours since this change, but the common occurrence of fuel pressure falling to 2 psi is now a very rare occurrence of fuel pressure falling from 5 psi down to maybe 4 or 4.5 psi, never lower. At idle with the electric pump off (and the engine driven pump running slowly) I occasionally see a fuel pressure down to 2 psi but never in flight.
I believe the internal resistance of the electric pump is a significant cause of the in flight fuel pressure fluctuations. I am not a fluid engineer, or engineer of any type, so this info is "for what its worth". Perhaps it will be of use to someone...
I would be happy to provide more detail or pics of my assembly.
Pics here:
https://picasaweb.google.com/1176086...3490/FuelPSI02
