If you're concerned about damaging the engine mount, you could use a drill bushing in the mount "eyes" to drill centered starter holes. Then you could use a reamer, after the mount is removed from the firewall, to enlarge the holes to full size.
I didn't do this...I just used a drill bit. But I think the undersize-then-ream is possibly the cleanest way to do it. Just my 2 cents.
Dan Checkoway RV-7
