Old 03-16-2014, 08:37 AM
AlexPeterson's Avatar
Default Airbox sandblasting?
Greetings,
As I've learned is necessary, one must inspect the FAB plate regularly for cracks, since there seem to be only two types of these plates - those that have been replaced and those that will be... No cracks on mine this time, although I'm on the 3rd or 4th one now at 1400 hours.
Apparently, sand from the nose gear finds its way up the fairing, and promptly gets blown (with vigor!) against the top aft end of the FAB plate.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 03-16-2014, 10:08 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Wow, that's really interesting! My first thought is wondering how much paint is left on the face of the prop blades :-)
I can't quite picture the flow that causes the results shown in your picture. Any evidence of similar abrasion on the fiberglass portion of the air box?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 03-16-2014, 10:15 AM
I think all of the sand that normally would go up my fairing is blocked by all the oil coming down it.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 03-16-2014, 10:21 AM
Ironflight's Avatar
VAF Moderator / Line Boy
That much sand means you're following the snow plow too closely Alex....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-16-2014, 12:17 PM
Jesse's Avatar
Jesse Jesse is offline
I'm on the same page. We have 1,300 hrs on our -10 and the plate is fine.
Jesse Saint
Old 03-16-2014, 12:33 PM
My guess is that the nose wheel picks up sand and deposits it in the wheel fairing as I taxi in and out. There is often a little pile of it under the wheel fairing opening in the hangar. Airborne slip stream is what motivates it up the gear fairing. Then some mysterious airflow in the cowl smites it into the FAB plate.
The prop leading edges do get a little dulled, but that is simply part of winter flying. I take some Scotchbrite to them to shine them back up.
My technique to minimize the sand blasting is to take off towards the side of the runway, and to advance the throttle very slowly.
Alex Peterson
KADC, Wadena, MN
