Go Back   VAF Forums > Main > Reviews
Old 03-15-2014, 08:58 AM
scrollF4's Avatar
scrollF4 scrollF4 is online now
Moderator, Asst. Line Boy
Default ASA Oil Seperator -- bottom-line reviews
I have read a lot of great reviews in these fora supporting Anti-Splat's ASA Oil Separator, and I have a question for the group: Has anyone had difficulty with, or been disappointed by, the system, particularly regarding its performance?
I ask because I'm at the perfect point to order and install, and want to make sure I'm making the wisest choice.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 03-15-2014, 11:15 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
Default Did not help in my case
Hi Scroll,
I am also at 52F and installed the ASA air/oil separator on my RV-10. I was hoping the slight negative crankcase pressure would reduce some of the weeping and that the belly would stay cleaner. Unfortunately it did not help on the oil weeping and the belly still gets dirty. I saw no change in oil consumption or any noticeable power increase.
Just one data point....
TJ
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 03-15-2014, 08:36 PM
scrollF4's Avatar
Default RV-10 oil seperator
Thanks TJ.
It occurred to me that ASA's video discussed a larger oil separator for the RV-10 engine, but then their product list showed only one size separator. Do you have that standard ASA separator on your 200+ hp engine?
Scroll
Exemption waived.
Old 03-15-2014, 08:54 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Bottom line is that for me it was simpler and faster to install than the bent aluminum tube supplied with Vans kit.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 03-24-2014, 04:14 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Originally Posted by Flying again! View Post
Hi Scroll,
TJ
...I am sorry to hear this and if you would like I will help you resolve the issues you are having. I boast regularly that we don't have any unhappy customers and prefer to keep it so. I suspect there is something different in your installation. At any rate, please feel free to give us a call so we can help. We have been manufacturing this product since early 1970s and have literally thousands in use. If you honestly are unhappy with your results you can also return the product for a full refund at any time. Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 03-24-2014, 07:51 PM
Norman CYYJ Norman CYYJ is offline
Now that's the type of business that I like to deal with, one that provides service.
Old 03-25-2014, 07:06 AM
dealfair dealfair is offline
Default Thumbs up
I'm loving mine Sid. I have an O-320. The oil consumption has always been low and I don't notice any difference; but it certainly has cleaned up the plane's belly. I'm really impressed with that. Allan being so easy to deal with is icing on the cake.
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
Old 03-25-2014, 07:10 AM
Geico266's Avatar
Geico266 Geico266 is offline
Just ordered the kit. Can't wait to get it installed. The blow by on my IOX-360 is pretty bad. This should be a good test for the ASA kit.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-25-2014, 08:14 AM
rocketbob's Avatar
There are four ways oil leaves the crankcase: 1: past the rings and into the exhaust, 2: out the breather in the form of mist, 3: past the valve guides, and 4: leaks at seams.
One drip a second ends up being a considerable amount of oil.
A large majority of the time oil gets out thru the breather because of the poor breather design inherent to Lycomings. But in the other cases, a separator will not help. So just because a separator doesn't solve the problem, doesn't mean the separator isn't working effectively.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-25-2014, 08:26 AM
scrollF4's Avatar
Default Follow-up
I appreciate the feedback, gang. My separator arrived the other day, and I'm installing it today. It'll be a while (months?) before I start the engine, but I'm looking forward to the clean belly.
Allan, the white powder coat and blue tubing are going to look great under N260KM's hood.
Scroll
Exemption waived.
