Old 03-15-2014, 06:19 AM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Anyone using the AP-60 audio mixer?
Is anyone using this? its looks like a nice alternative to an audio panel. But, im not sure how you switch between sources (ie com 1/2 and nav 1/2)
http://www.aircraftspruce.com/catalo...?clickkey=7381
Old 03-15-2014, 08:02 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
You would need some kind of switch to control a four pole double throw relay which would then make the connections between the selected radio to the audio panel and PTT switch to the radio. One switch/relay setup for the Nav and another for the Com.
You can also use two mixers (One for each Nav/Com) and use a selector switch to apply power only to the one connected to the nav/com you want to use. Problem is that you can't use one nav and the other com at the same time but a lot easier to wire up.
As you can see it is a bit of wiring, but it can be done.
Old 03-15-2014, 10:16 AM
You need one double throw, double pole switch to swap the mike and PTT lines between com 1/com 2. For 'switching' everything else, just turn up or down the volume controls, like the 1970 era 152s many of us learned to fly in.
BTW, if you are at all handy with a small soldering iron, you can build your own mixer for $5 worth of electronics (connectors may cost a few dollars more). Google 'mixer circuit' and/or 'op amp'.
Old 03-15-2014, 10:37 AM
SHIPCHIEF SHIPCHIEF is offline
I bought one but didn't use it.
I bought all TERRA gear; NAV,Comm, ADF, Transponder. Many years ago when it was the lightest, best stuff. (Too bad it took so long to build the plane.)
All of it can be connected together according to TERRA's diagram, so the AP-60 wasn't needed.
I don't have 2 comms tho-. If I did, I would consider the PS engineering PMA 4000 mini audio panel.
http://www.ps-engineering.com/pma4000.shtml
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 03-15-2014, 03:20 PM
blueflyer's Avatar
even having to use switches, I would have thought more people would have used (or at least tried) this option for listening to multiple audio sources. maybe there is something else about this that I am missing.
Old 03-15-2014, 03:49 PM
vlittle's Avatar
vlittle vlittle is offline
Here's a link to some documentation on how to do what you want. http://54.204.241.138/redmine/documents/16
Cheers
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 03-15-2014, 04:47 PM
Almost everyone these days wants an intercom, and you can get intercoms with 'unswitched inputs' (a mixer) for little more than the intercom itself.
Old 03-16-2014, 06:49 AM
Mich48041 Mich48041 is offline
Bob Nuckolls designed a DIY audio isolation amplifier.
http://www.aeroelectric.com/Catalog/AEC/9009/9009-1.jpg
This pcb file: http://www.aeroelectric.com/Catalog/...009-300-2A.pcb requires a free program to open. Download it here: http://www.expresspcb.com/expresspcbhtm/download.htm Here are the complete instructions: http://www.aeroelectric.com/Catalog/.../9009-700L.pdf
Bob used to sell a ready to use amplifier, but is in the process of selling the business.
Joe Gores
Old 03-16-2014, 08:29 AM
vlittle's Avatar
Cheers
Forgot to mention, this is open source.... here's are the files http://54.204.241.138/redmine/projects/amz-2a/files
You can make your own, buy the pcb, the kit or the whole device.
V e r n. ====
RV-9A complete
S-21 wings complete
Old 03-20-2014, 07:13 PM
blueflyer's Avatar
Originally Posted by BobTurner View Post
......... For 'switching' everything else, just turn up or down the volume controls, like the 1970 era 152s many of us learned to fly in......
Are you saying that I could run the 2 nav audio wires straight to the headphone jack (and run the wire from anything else I want to hear straight into my headset)?
