Old 09-19-2006, 09:11 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
Default Which oil drain plug?
Just got my quick-drain oil plug and am wondering which hole to install it in -- both seem relatively unobstructed, at least at the moment. Any advice?
This is for an RV-9A w/ O-320 and stock FWF stuff.
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 09-19-2006, 11:24 AM
Mel's Avatar
Mel Mel is offline
On an "A" model, it really shouldn't matter as the sump is relatively level. Just remember, you want to drain the lowest point. Have you installed the exhaust (with heat muffs)? That's probably the biggest obstruction.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-19-2006, 02:06 PM
Rick6a's Avatar
Rick6a Rick6a is offline
I used the plug on the starboard side of my O-320 D1A because it is aft of the plug on the port side, hence it is at a slightly lower location given the posture of my 6A at rest.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
