03-14-2014, 03:04 PM
Copper Crush Washer On Oil Pickup Screen
I wanted to order a few copper crush washers for the oil pickup screen on my Lycoming sump. I got what they told me was the replacement part for what I had. The part number is MS35769-21. the -21 denotes the inside diameter of 1" which is correct. But my oil screen pickup has a hard flat copper washer on it. The part they sent me is a round copper case with fiber material in it. It's meant to be crushed but is that ok to use on the pickup screen? I'm hoping someone has experience with this.
Richard Fazio
LI, NY
N966RV
RV-6 Slider
O-360
FP Wood Prop
03-14-2014, 03:11 PM
The one they sent is correct, throw the other one out.
Senior Curmudgeon
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-14-2014, 03:32 PM
Thanks guys, I knew I would get the right info here.
Richard Fazio
LI, NY
N966RV
RV-6 Slider
O-360
FP Wood Prop
03-15-2014, 01:05 PM
Related question (sort of): The torque value for that bolt and gasket as I recall was something like "finger tight plus 135 degrees." I get a fair leak out of that spot at finger tight plus 135 degrees. so what are my options here. Tighten it more and violate the torque guidelines or just accept an oil drip there?
Also, I can never remember the rule of thumb for crush gaskets. Does the seam part face TOWARD the engine or AWAY from the engine?
03-16-2014, 10:12 AM
Split side goes to case and I tighten them a little bit more than the +135 degrees. Something like 20-25 FTLB, whatever feels good and tight.
Byron
1977 Mooney 201
Houston, TX
03-16-2014, 12:18 PM
The trouble is ... if you tighten too much (more than the desired crush) the leak will leak more.
If it's only a drip, it might be worth trying a light application of fuel lube on the washer.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
03-16-2014, 02:00 PM
Use this as a reference -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
