Go Back   VAF Forums > Model Specific > RV-9/9A
  #21
Old 03-13-2014, 09:30 AM
whd721 whd721 is offline
Great Video!
The small cameras show many what only one saw before. Knowledge is spread.
The stall as shown seems to be gradual from the trailing edge, for approximately the inboard 1/3 of the wing, then zips out to the tip.
Is that visual stall, what you actually feel yourself?
That is, can you feel and can you control, holding just short of the complete stall, that matches the visual stall?
I will try again, can you see the "drop" with the tuffs as you feel it?
whd721
RV9A
Sherwood, Oregon
As Bill Stout (designer of the Ford Trimotor) used to say, ?Simplicate and add Lightness?
Old 03-13-2014, 04:30 PM
Steve Melton's Avatar
Default you bet
Originally Posted by whd721 View Post
Great Video!
yes, you can feel it and see it at the same time.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 03-14-2014, 01:23 AM
ao.frog ao.frog is offline
Default Great job!
Thanks for a very good video! It was very useful seeing how good that wing is in real life.
Great idea with the full flap stall too. (The -7 video)
If you are to do more tests; any chance that you can do one with t/o flaps on the -7?
Once again: thanks for the effort! Job well done!
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
