Go Back   VAF Forums > Model Specific > RV-9/9A
Old 03-12-2014, 05:11 AM
Steve Melton's Avatar
Default RV-9A and -7A stall testing with wing tufts
RV-9A
http://youtu.be/qeSoO3nXjjI
added as update
RV-7A
http://youtu.be/ECTCVgiBHjA
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 03-12-2014, 07:47 AM
Interesting Steve. It's doing it just as it was designed to.
You built a straight airplane.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 03-12-2014, 08:41 AM
PeteP's Avatar
PeteP PeteP is offline
Default Nice!
Steve - Nice job and a clean stalling wing. Thanks for the vid.
Pete (AKA Yoda)
Exempt but VAF 2017 Dues Paid anyway
Old 03-12-2014, 09:58 AM
apkp777's Avatar
apkp777 apkp777 is offline
Yep, the -9 stalls with very little loss of aileron control. If you accelerate the stall you get get to extend past the ailerons and even get a bit of a tail stall. That one gets your attention, but still docile. Those of us/you that have stalled a C152 with wings out-of-rig will have a hard time finding a similar stall induced excitement out of the RV9
Thanks for the video. I'd love to seem more (approach, accelerated, departure, cross-control, tail)
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 03-12-2014, 10:44 AM
Default my question
why does the wing stall inboard first? It's a straight wing with constant cross section.
I like it. excellent control at slow speed.
Steve Melton
Cincinnati, OH
Old 03-12-2014, 12:11 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Can't speak for the -9, but if it is like every other wing I know about there is a washout in angle of attack as you proceed toward the tip. The inboard section has a higher angle of attack and stalls before the tips, allowing aileron control through the stall.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 03-12-2014, 02:31 PM
longranger's Avatar
Don
I see in your signature you have an 8. By plan at least there's no washout in those wings.
Miles (VAF# 1238, Paid up as of 12/20)
RV-7 TU 904KM (reserved)
Construction Log
Empennage Album, Wings Album, Fuselage Album
Old 03-12-2014, 02:55 PM
apkp777's Avatar
I don't think any RV's have "washout" or "Twist", but I'd love to hear one of the smart guys here in VAF explain how the "Hersey Bar" wing produces the inboard aft stall that progresses outboard to the tip. I know it has to do with "spanwise" air flow that artificially lowers the stall speed at the tips, but for the life of me I can put it into intelligible words.
Tony Phillips
Old 03-12-2014, 04:41 PM
Default aerodynamicist (not me) says
"Because of the fuselage interference, the wing root is likely seeing a lower flow speed as flow wants to move away from the fuselage (transverse direction) towards the wing tip at the wing root. Therefore the axial flow velocity at the wing root is lower than the wing tip and that is why you are seeing separation at the root first. From the motion of the tufts, I see that when the inboard separates, the separation is from the LE all the way to the back (80-90% chord). Not sure what your speed was at those points, but I would imagine that this is a laminar flow separation starting at the wing LE. The solution to this could be as simple as putting a series of vortex generators (1-2 rows) to induce some turbulence and suppress the premature flow separation."
Steve Melton
Cincinnati, OH
Old 03-12-2014, 05:56 PM
David Z David Z is offline
The idling prop will be blocking a good portion of the airflow over the wing root as well.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage deburring and dimpling. So many holes
83126
Dash 8 day job is financing the RV8
Donation till September 2022
