Old 03-11-2014, 07:19 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Default Oddball Induction System
This probably qualifies as an oddball scenario, but I'm curious if anyone has ever adapted a forward facing fuel injection servo, through a filter, to a lower cowl intake snout (formerly updraft).
I'm aware of the various intake and filtration options for forward induction engines. Just exploring options that don't have me chopping up the cowling a second time in two years.
Bryan
Old 03-11-2014, 07:24 PM
vfrazier's Avatar
vfrazier vfrazier is offline
That's what my Rocket had. The filter section doesn't have to be removable, but you'll likely have to put a small door in the cowl bottom to attach the induction SCAT to the airbox.
Some photos and text here: http://vincesrocket.com/cowling.htm
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 03-11-2014, 08:02 PM
Low Pass's Avatar
Thanks, Vince! Very nice system. If I have to cut, I will definitely keep your design in mind.
Old 03-11-2014, 09:44 PM
rph142's Avatar
rph142 rph142 is offline
I made it work on my rv-3. Check the fwf page on my website www.myrv3.com for details. I had to make my own filter air box and modify the lower cowl a little. It worked great in the end, although it was a lot of work.
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 03-12-2014, 07:17 AM
9GT's Avatar
9GT 9GT is offline
I did on my -10. The engine I used is a V4A5 instead of the D4A5 so it was either swap out the sump or modify the intake. I fabricated an aluminum air plenum box that bolts to the front of the servo and I made a a fiberglass cone that mounts to that which holds a K&N cone filter. I had to do modification to the lower cowl also.
David C.
Howell, MI
Old 03-12-2014, 12:06 PM
JonJay's Avatar
JonJay JonJay is offline
Russ McKutcheon has been flying his 4 for years this way, and it flew for years before him. No filter at all.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-13-2014, 07:36 PM
Low Pass's Avatar
Default Thanks for the replies...
I appreciate the thoughts. So it sounds like I might be able to come up with something in lieu of chopping up the lower cowling. Will hold off on the snorkel order and wait to see how the engine fits with the lower cowl.
Thanks!!
