Old 03-10-2014, 07:03 PM
digidocs's Avatar
digidocs digidocs is offline
Default Conduit support spacing and floor contact
I'm thinking of running a flexible conduit under my baggage floor similar to what Tim shows below. Two questions for the VAF brain trust:
- How far apart should the conduit supports be?
- Is it okay for the conduit to rest on the floor as shown?
Thanks for the help,
David
Old 03-10-2014, 07:44 PM
bruceh's Avatar
bruceh bruceh is offline
You can let it just lay on the skin. To keep it from rubbing around, put a couple of blobs of proseal or equivalent adhesive under the conduit to stick it in place.
Bruce Hill
2020 VAF donator
Old 03-10-2014, 10:19 PM
P51Matt P51Matt is offline
Here is what my dad and I did.
https://www.facebook.com/photo.php?f...1&l=baca50508b
https://www.facebook.com/photo.php?f...8&l=96b0a62a10
We just layed it in and clamped the ends with the slack pulled out.
Matt German
Lees Summit, Missouri
RV-10QB N142LM: Flying 240+hrs
RV-8 Eventually, working on Fuse
2020 donations done
Old 03-11-2014, 09:01 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is online now
Don't run the conduit under where the step bolt goes through. It will make installing or removing the bolt very difficult, and possibly chafe the conduit over time.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 03-12-2014, 09:25 AM
digidocs's Avatar
Thanks for the help guys. I will glue conduit down to the floor and avoid the step bolt area.
Fly safe,
David
Old 03-12-2014, 09:39 AM
Here is a photo of my installation. You can fab a bracket for the hole penetration at the rear
Bill Peyton
RV-10 - 1125 hrs
N37CP
