Old 03-09-2014, 03:35 PM
gear1 gear1 is offline
Red face Question on elevator balance
I have just completed SB 14-01-13, and during reassembly I have been inspecting hinge alignment and balance. My left elevator (with electric trim installed) balances perfectly. The right elevator, however is overbalanced (the lead weight is too heavy). A search of the VAF archives provided a wealth of information on balancing the control surfaces, but little on the effect of the weight being too heavy. The pitch control forces are quite light, and very well balanced with the roll forces; I understand that overbalancing the elevator will lighten stick forces. The stick forces are so well balanced now that I would not like to change the control balance.
My question is this: is it OK to have the elevator somewhat overbalanced?
Craig Taylor
RV8 flying
2020 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
Old 03-09-2014, 05:23 PM
131RB 131RB is offline
It is unlikely that the proper balance will change your stick forces enough that you will notice a difference. Error on the side of safety and balance the elevator correctly.
Ryan
Old 03-10-2014, 05:21 PM
TerryWighs TerryWighs is offline
I highly recommend checking this out with Vans building site. My memory of unbalanced elevators is a dangerous condition. Flutter? Are they balanced when both right and left connected together?
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 03-10-2014, 05:29 PM
Bavafa Bavafa is online now
It is recommended that each elevator is balanced individually and also as a unit (together). If you have not painted and planning on painting, I would not remove any lead (weight) till all the painting has been completed as it will affect the outcome.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 03-11-2014, 06:56 PM
Default Elevator Balance
Thanks for posting everyone. I did check with Van's, who indicated that a slightly heavy weight is fine, especially since the aircraft has flown for 1650 hours with no problems whatsoever. Since I like the way the controls feel I will leave it alone....
Craig Taylor
RV8 flying
