Old 03-09-2014, 02:17 PM
dbaflyer dbaflyer is offline
Default wing root fairing rivet interference
My wing root fairing with the rubber installed lays right on top of these two rivets which is just above where the main spar enters the fuselage. Should these be flush rivets so the rubber lays down flat?
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 03-09-2014, 08:31 PM
bruceh's Avatar
bruceh bruceh is offline
Those rivets were close on mine, but the rubber gap seal sits just fine on them. I wouldn't swap those out to flush rivets at this point, but for future builders it might be something to consider.
Bruce Hill
2020 VAF donator
