03-08-2014, 03:36 PM
What's limiting my RPM?
I have a new Lycoming 0-320, Catto three bladed prop (specified for my 9a with 160 hp engine) one Slick Mag and one P_Mag. The engine reaches a maximum of 2410 rpm full rich while burning 11gph. TAS is less than 140 knots without pants and fairings. (About 20 knots less than I'd expect)... I've checked throttle and mixture linkages for full range of travel. I plan to call Catto to ask about the pitch of the propeller but is there anything else I should be looking at?
03-08-2014, 03:55 PM
You will be very surprised what correctly installed fairing and pants will do.  What Gen prop do you have and what is the pitch?
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
03-08-2014, 04:16 PM
Between pants and fairings and leaning to best power I suspect your numbers will improve quite a bit.
George
03-08-2014, 04:19 PM
Sounds just about right to me. Please don't bother Craig before you are in the final configuration that you are going to fly with, including pants and fairings.
Scott Card
CMW E-Lift
03-08-2014, 04:43 PM
Leaning
Adjusting the mixture yields no higher rpm. Would you expect the addition of pants and fairings to bring rpm up by 300 - 400?
03-08-2014, 04:49 PM
Senior Curmudgeon
What Scott said.
Quite right, get it all finished before looking at changing the prop.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-08-2014, 05:03 PM
Double check the ignition timing on both mags. Also check your tach accuracy against a handheld digital tach.
Neal Howard
Airplaneless once again...
03-08-2014, 07:30 PM
Check your static is correct by running a GPS box and copare the TAS indicated to TAS from the GPS box. You could have a big error.
If your RPM is definitely right you might have a dog of a prop. I wonder about Jamie Lee's RV7A, it is slow too with a 3 blade Cato.
Others get a good result? So who knows. I have had timber laminate props that measure the same for pitch on a jig, yet one to the other are daylight and dark. We could never work out why.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
03-08-2014, 07:40 PM
The rule of thumb is 10 knots for the gear leg fairings and another five for the wheel pants.
Fairings and other tweeks may add another five.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-08-2014, 08:26 PM
Quite possibly. Your prop is designed for a 160hp RV9. With no fairings or pants you have significantly more drag. ie...you're not flying a RV-9 profile.
