I can buy 100 degrees, and 120 degrees, but the only source I have found for a 110 degree countersink is $300. What are the rest of you using for attaching thin dimpled sheet to thick base stock? 100 or 120 would get the job done, but it does not seem right. I can't believe everyone is buying a $300 countersink, so I must be missing something...
Aircraft Spruce has various piloted stop countersinks available at reasonable prices. Non piloted from mscdirect.com, most industrial hardware stores have the plain countersinks starting around $15-20
