Originally Posted by MXpilot1
I recently purchased a set of pushrod boots for my -6 from flight line interiors. These boots are obviously made to install with the wing off. I fabricated an aluminium plate per the supplied template and planned to squeeze the boot between the plate and the inside of the bulkhead. The problem is, I can't get a drill between the floor ribs to drill rivet holes in the bulkhead. Any suggestions?
Unless since modified, the aluminum ring/plate is my design. At the time Abby had yet to receive any -6 series orders and the -7 series template she did sent me for the aileron boots would not work. After several phone calls and more than a few ill-fitting boots crossing the mails, I finally made up an aluminum ring/plate that would work and sent it to her. She traced the template and sized the boot fabric to its dimensions.
Anyway, I ended up using 2 rings per side, installing nutplates on the interior plate, attaching the assembly from the outside with screws and sealed with RTV. Admittedly, the photo makes it difficult to tell that the fasteners are actually hex head screws.
I'm a bit confused because you say you cannot get a drill between the floor ribs. If memory serves, a right angle drill motor fitted with a short drill bit cut to size should work. What am I missing? Can you post a detail photo of the area in question?
