Old 03-04-2014, 11:15 AM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
Default Replacing conical engine mounts in-situ
I've decided to 'bite the bullet' and replace the old hardened engine mount bushes in my RV-4 with a set of J-1552 Lord mounts in place of the old 71032 Lycoming ones.
I'm told that they are dimensionally equivalent, so no bolt length etc changes.
My plan is to support the engine, loosen all the mount bolts and then replace the bushes one at a time without removing the engine.
Has anyone tried doing it this way or anticipates any problems with my plan?
Old 03-04-2014, 12:29 PM
chrisbryanolsen chrisbryanolsen is online now
Default Need to do the same
Mark,
I need to do the same thing, so let me know how it goes.
Chris Olsen
Chile Flight
N2ZK RV-4 @ KAEG
Dues Paid Nov. 2019
Old 03-04-2014, 12:32 PM
DougJ's Avatar
DougJ DougJ is offline
Mark, aren't the 71032 and equivalent for conical and the J-1552 for dynafocal mounts?
I have a conical mount O-320 and I'm planning to buy a new set of Lycoming bushings, Spruce PN 05-08074, or the "HOMEBUILDERS CONICAL LYCOMING ENGINE MOUNT BUSHINGS" Spruce PN 08-00662. Both of those are 71032 equivalent.
I will utilize an engine hoise and try to replace them with as little additional teardown as possible.
Old 03-04-2014, 12:55 PM
Doug,
AIUI the J-1552 is a higher performance, and more expensive, direct replacement for the conical rubber bushings for conical mount engines.
My engine was originally from a Tri-Pacer.
I think that the mounts should be a lot easier to replace than on a Dynafocal mount as the bolts are all parllel.
Old 03-04-2014, 05:14 PM
vic syracuse vic syracuse is offline
Super Moderator
I just replaced these on an RV-6 and used the J-6230-1 Lord Mounts. It does require a little bit of work, but it is easier than the Dynafocal mounts.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 03-04-2014, 06:21 PM
Vic,
I think that those mounts are the eccentric ones that need an indexing pin to be added on to the mounting pads of the engine frame.
My understanding is that the J-1552 is very similar but concentric, so doesn't need indexing and is a drop-in replacement for the 71032.
I think Van's sell the J-6230-1 as "EA CON VIBRATION ISO".
Old 03-04-2014, 06:48 PM
Super Moderator
Default Pins
You are right, but they were very easy to clock.
Vic Syracuse
Old 03-04-2014, 08:48 PM
Toobuilder's Avatar
I've done several sets of both conical and dynafocal mounts "in situ". Do two at a time (top or bottom) with the engine supported by a hoist at the prop. Raising or lowering will open plenty of gap to slip the mounts in and out. Just watch for control cables or hard interference against the engine mount, exhaust, etc. usually, there is enough flex/clearance to open quite a gap.
The hardest part, really, is getting the cotter pin installed in the upper left side without screwing up the pushrod tube.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-05-2014, 06:12 AM
Super Moderator
Default pushrod tube
Yes, it is very easy to damage that pushrod tube if one is not careful. Turning the bolt around seems to provide a lot more clearance.
Vic
Vic Syracuse
Old 03-26-2014, 05:27 PM
I've just received the j-1552 Lord mounts.
They seem to differ from the Lycoming 71032 bushes in that there is a 3/4" counterbore around the 1/2" bolt hole.
I presume that is for an internal spacer that I don't have with the Lycoming bushes.
Does anyone know if that is correct or have a source and part number for the spacer?
Also, if there is a metal spacer then I presume the torque requirement would be more than the 40-60 in-lb that the Lycoming bush uses.
Any pointers would be appreciated.
