Old 03-03-2014, 10:15 AM
walkman's Avatar
walkman walkman is offline
Default Loose nut in the cockpit! Help me identify
Yesterday after flying, including some mild acro, I found this loose nut lying on the floor in the cockpit. Operationally everything checks out, heck I made it home. However I'm a little worried and I'd like to figure out where it came from. Its possible it could have been rattling around for years, as I've done the only inverted flight this airplane has seen in 7 years and I've been rained on by gravel, wire tie ends, pens, and various other detritus that builds up over the years.
Does anyone recognize where this might have come from?
https://www.dropbox.com/s/kmcr3ylure...2012.17.38.jpg
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 03-03-2014, 10:27 AM
Paul K Paul K is offline
If your photo is close to being in scale, looks like a 1/2 inch galv thin nut. Honestly, I don't think my 7a has anything like that in the cockpit! I don't know if there is any 1/2 inch hardware on the entire plane.
With that being said, I would spend some time going over the plans looking for anything like this. Again, verify the size and start with the plans. Engines have some larger hardware, just not galvinized. Case bolts, cylinder bolts, etc.
Good luck.
Paul K
West Michigan
2021 donation made, exempt but worth every dime!
Old 03-03-2014, 10:31 AM
Sid Lambert Sid Lambert is offline
Some kind of jam nut for a heavy electrical terminal?
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 03-03-2014, 10:48 AM
mikeflys8's Avatar
mikeflys8 mikeflys8 is offline
Default Loose Nut
Looks Like the Jam nut from the end of a control cable....throttler, mixture, prop....?
Old 03-03-2014, 10:50 AM
ppilotmike's Avatar
I thought all cockpits contained at least one "loose nut!"
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Geico266's Avatar
Geico266 Geico266 is offline
Don't think those would be flying around even if they came loose. I guess he could have dropped one during construction.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-03-2014, 10:51 AM
Geico266's Avatar
Only in flight.
Old 03-03-2014, 11:08 AM
walkman's Avatar
Good luck.
Unfortunately I don't have the plans for this airplane.
It doesn't look like standard aircraft hardware to me.
The prior owner was a builder/construction guy.....so perhaps it migrated into the airplane from somewhere else, a job site or something.
Old 03-03-2014, 11:27 AM
kjlpdx kjlpdx is offline
some battery terminal hardware? maybe ground cable to firewall grd post? we used to joke about at the monthly meetings leaving odd parts in builders planes just to have them scratching their heads. maybe you were had.
RV-6A 1500+hrs since 1997
O-320 D2J, FP, slo-bld
49 states, Bahamas, Canada
2014 - PAID
Old 03-03-2014, 11:46 AM
BillL BillL is offline
I can not tell what size it is, but it appears to be a fine thread. You could help by giving the thread pitch and wrench or bolt size more precisely.
Like others maybe a solenoid jamb nut.
I got some hardware store nuts for all my assembly checks where a castle or fiber locking nut was used. I drop them all the time, but have tried to keep the inside cleaned regularly, but it could have jumped in a crevice and just finally rattled out. There are some of those places on the forward fuse floor on a 7.
Actually can not think of a cockpit item that size, but the way I work the forward skin is not on until the end and I sit a cut down box up there with stuff in it as a working area.
Good luck, maybe time for a good inspection, never know what you will find.
Bill
RV-7
