Originally Posted by painless
Is it possible that this amount of undercamber in my right aileron is creating a slight amount of lift enough to make me roll to the left?
The undercamber might be contributing to your problem, but the mechanism is slightly different than described.
The undercamber would be forcing the air to change directions as it tries to follow the contour of the aileron skin. Newton's first law tells us that the air won't change direction unless a force is applied to it. The required force comes from changes in air pressure at different parts of the aileron surface. If the contour of one aileron is different from the other, this leads to differences in the pressure patterns on the two ailerons. This difference in pressure will cause the ailerons to deflect a little bit even when you aren't inputting any lateral stick force. This small aileron deflection causes the aircraft to want to roll, and is felt as a wing heaviness.
I have a hard time trying to figure out whether an undercamber on one aileron would tend to make it deflect up or down. I think this would tend to make the right aileron want to deflect up, which would make a right wing heavy condition. But, this could have been masked by the effect of one aileron hinge being higher than the other, which may have been forcing the ailerons to deflect in the other direction, causing a left wing heavy condition.
