Old 09-17-2006, 07:24 PM
Rainmaker's Avatar
Rainmaker Rainmaker is offline
Default Return part or fix it?
Ok So I got my tail kit! Yeah
Everything was there upon inventory. Woopee!
However the left elevator horn has had some of its powder coat chipped off. Should I return it to Vans for a replacement or just sand and prime it now?
Matt Mulder
RV-7
Working in the cabin area somewhere
http://n07m.wordpress.com/
VAF#950
Old 09-17-2006, 07:27 PM
painless painless is offline
Matt:
Van's sells a bottle of touch-up paint that you can cover this area with.
Now get busy and drill some holes!
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 09-17-2006, 07:34 PM
Squirt it with a can of rustoleum or equivalent. If you worry about little things like chipped paint on weldments, you'll get trapped in unimportant details, won't enjoy the project, and will never finish it.
For the next 3 (?) years your task is to move your project forward a little bit every day while overcoming a gazillion little setbacks along the way...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-17-2006, 09:21 PM
az_gila's Avatar
az_gila az_gila is offline
Cool Yes... but...
But the correct thing to do would be to clean off the corrosion that is already visible before you "squirt it"... A Scotch Brite disk in a die grinder would do it in seconds....
You should worry a bit about corrosion the has already started on bare steel. I would not rate it as unimportant like Kyle....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-17-2006, 09:52 PM
Rainmaker's Avatar
Thanks!
I know it's a total newbie question, but being one of the few steel parts I figured I'd be a bit over cautious with it. OK. touch up paint ordered. Now where did I sit my drill?
Matt Mulder
RV-7
VAF#950
