Old 03-01-2014, 04:49 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Default Garmin 796 and Navworx help
Does anyone have a Garmin 796 and a Navworx ADSB that the 796 has not been upgraded ? I need a picture or settings in the Garmin prior to the latest Garmin version upgrade. After upgrading my Garmin I do not receive data from the Navworx and the same with my one of the other RV pilots in the area. I am reading data from the Navworx to my GRT and traffic is still working correctly on the EFIS. But no joy with the Garmin
I read the manual and there is a TIS In/NMEA & VHF out option. This option is not there after the upgrade. Unfortunately I cannot find the photo of my settings prior to the Garmin upgrade.
The GTX TIS A setting does not work with the Navworx.
Any help would be appreciated
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2020 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 03-01-2014, 05:09 PM
Walt's Avatar
Walt Walt is offline
Should be TIS-A In/NMEA VHF out, make sure the baud is set to 9600.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-01-2014, 05:44 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello David,
Have you installed the V4.10 Area 796 software?
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-01-2014, 07:37 PM
Dvalcik's Avatar
Originally Posted by g3xpert View Post
Hello David,
Steve
Steve I installed the latest version last weekend.
Walt see the Photo of the 796 screen, I don't that option anymore after the update.
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2020 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
Old 03-01-2014, 08:02 PM
g3xpert's Avatar
Post
David,
"TIS In" and "GTX TIS-A In" are the same thing. The TIS-A designation was added to remove confusion between TIS-A and TIS-B.
Please be certain you are using V4.10 and not something older.
Steve
Garmin G3X Support
g3xpert@garmin.com
