Old 03-01-2014, 04:40 PM
pilot28906 pilot28906 is offline
Default F-721 Aft Canopy Deck Questions?
1) Did you countersink the aft deck or dimple the aft deck and countersink the longeron?
2) What is the best way to set these rivets?
John Johnson
Murphy, NC
RV7
Old 03-01-2014, 06:16 PM
AlphaCharlieBravo AlphaCharlieBravo is offline
Default F-721
Hey John
I machine countersunk the aft deck, not the longeron. I also pre-riveted the F-721A to the F-721B so I could use solid 426 rivets. Those two holes on each side were dimpled. As far as the best way for me was my Webster tungsten bucking bar fit up inside there nicely. What I like to do is wrap a fair amount of blue painters tape around the bottom to hold it out from the skin the width of the longeron. That way I just put it under the aft deck hold it straight and shoot nice rivets without having to worry how far to hold it away from the skin. Works for me.
There are two on each side above the uprights for the 404 bulkhead which are going to require some thought. I haven't installed those yet.
I installed the F-704K cap strips inadvertently before installing the decks and had to drill all the rivets to remove them as I had tool blocked myself installing some of the remaining deck rivets. Hope this all makes sense.
Arnie Barros
VAF #1401
(N89269) reserved
"Seek to understand before trying to be understood"
Old 03-01-2014, 07:37 PM
Thanks Arnie.
John Johnson
Murphy, NC
RV7
