Old 03-01-2014, 11:31 AM
pierre smith's Avatar
Default Certified as well
Both of my certified Air Tractors have the same rod end bearing hinge as Van's and they have locking nuts from the factory.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-01-2014, 12:08 PM
az_gila's Avatar
az_gila az_gila is offline
Cool
My main point is "do not become complacent and assume that just because an AN365 nut has been replaced and is now safetied with a cotter pin, that it is automatically safer".
If you really, really want "belts and braces" then you can use a self-locking castle nut...
http://www.aircraftspruce.com/catalo...es/ms17825.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-01-2014, 03:11 PM
Walt's Avatar
Walt Walt is offline
There have been numerous documented accidents due to a cotter pin that was left out but I can't recall every hearing of a "good" self locking nut departing for no reason.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-01-2014, 03:48 PM
Jamie's Avatar
Jamie Jamie is offline
My thoughts exactly. There is a trade-off. The only way that nut is going to back out is if the bearings in the rod end-bearing fail or something else causes the rod-end bearing to lock up, then rotation could be applied to the nut. But, the rod-end bearings are supposed to be sandwiched between the adjacent tabs (read: tight). If the bearing fails it should be very, very obvious.
But I too have seen many missing lock nuts. Once even on a rental I was going to fly as a newly-minted pilot. It was a 172 and during my walk-around I noticed that there were no cotter pins on any of the castle nuts holding the right aileron on. Turns out the aileron had been pulled so that part of the wing could be inspected -- two weeks prior. Countless students flew that airplane like that.
Old 03-01-2014, 08:55 PM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
I understand about a cotter pinned nut on a rotating bolt, but why do we use a cotter pin on the bolts that hold the engine mount on?
Just wondering if its because of the tensile load instead of the shear load?
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 03-01-2014, 11:01 PM
Bevan Bevan is offline
Probably because fiber nuts are not to be used FWF (temp limits).
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 03-02-2014, 01:10 AM
RV7A Flyer's Avatar
Bevan
Somebody needs to notify Lycoming, then, because my brand new IO-360 from the factory came with (gasp) fiber locknuts on it (e.g., on the Adel clamps holding the fuel injection lines).
I've heard this before about fiber locknuts FWF, and granted there are places in the engine compartment where they probably shouldn't be used (and I used a lot of all-metal locknuts when installing the systems on the engine), but even the fuel injection servo uses fiber locknuts in one or two places, IIRC.
Old 03-02-2014, 03:41 AM
plehrke's Avatar
plehrke plehrke is offline
Engine mounts are also a high vibration joint with rubber in the clamp-up stack. Both vibration and movement can work a nut off a bolt unless mechanically restricted with a cotter pin.
Philip
RV-6A - 14+ years, 950+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 03-02-2014, 04:28 AM
TomVal's Avatar
TomVal TomVal is offline
Heck, on my fixed pitched prop, even Sensenich uses self-locking nuts. I was surprised to see this, but that's what their documentation shows.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 03-02-2014, 06:44 AM
vic syracuse vic syracuse is offline
Super Moderator
Default Cotter pins
I just inspected an RV-10 yesterday with 100 hours on it and NO cotter pins in any of the 4 engine Lord mount bolts.
If it calls for them, they have to be used.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
