Old 09-17-2006, 06:36 PM
AX-O's Avatar
AX-O AX-O is offline
Talking Done with my -8 tail
Ok, this may not be a big milestone for some of you out there but it is huge for me. It took me 165.5 hrs to finish all the metal work. The fiberglass tips will be done later. I will start working on the wing in a few days.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 09-17-2006, 06:52 PM
N674P N674P is offline
Default Congratulations!
Axel-
It is a big deal, and it looks great! Congratulations, and keep up the good work!
Johnny Pruett
VAF #601
-9 fuselage standard kit on hand
Slooow build wings still in progress...
Old 09-17-2006, 06:56 PM
jcoloccia jcoloccia is offline
Talking
LOL...took me about 165 days...
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 09-17-2006, 10:15 PM
G-force's Avatar
G-force G-force is offline
Looking good! Congrats!
Mike Sumner
Castaic, Ca
Old 09-18-2006, 07:37 AM
CraigC CraigC is offline
Nice looking empennage! Good looking jig post also. Is that a metal post?
Craig C A&P/IA
Mesa, AZ RV-8 SerNo 82582
Wings/Fuse N18VA Res
Old 09-18-2006, 08:37 AM
praterdj praterdj is offline
Great Job. You are ahead of me.
Donald Prater
Formerly 52F now Arkansas...Go Hogs!
RV-8 Empennage Underway
N-284DP (Reserved)
Old 09-18-2006, 10:49 AM
AX-O's Avatar
Craig click HERE
I talk about it on my web page.
Axel
Old 09-20-2006, 07:22 PM
prkaye prkaye is offline
Default rivet lines?
Hi AX-O,
Great looking job on your empennage! It looks from the photos that you primed along the rivet lines along the outside... or am i mistaking what I'm seeing?
If you did prime there, do you plan to remove the primer along these rivet lines later, and re-prime the whole thing prior to painting? Did you just do this to prevent corrosion on the HS along the rivet lines while it's in storage? I've thought about doing this myself...
Phil
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 09-20-2006, 07:56 PM
AX-O's Avatar
Originally Posted by prkaye
Hi AX-O,
Phil
Phil,
I primed under every hole that required a rivet. I wanted to have primer between the rivet and the skin. This was over kill and I do not plan on doing it on my wings or fuse. Takes more time and I don't know if it really helps. I plan on removing the primer and applying a new coat on the entire surface. If you notice, my primer lines got smaller and smaller with the experience I gained from the previous piece.
Axel
Old 09-20-2006, 08:27 PM
Did you use a self-etching primer?
Will you have to sand it off, or will paint-thinner or something take it off?
Phil
RV9A (SB)
Ottawa, Canada
