02-28-2014, 09:28 AM
Help: Build on or R&R this rivet?
I need some help deciding if this rivet is good enough, or if I should drill it out and replace it. This is the W-413PP inboard aileron hinge bracket, using AN470AD4-11 rivets. The shop heads are a bit small, but the 4-11 rivet was a bit short to start with, although that's what the plans said to use.
Is this head too deformed to provide the proper strength, or is it okay given the thickness of the material here?
Thanks for your input,
Rob
Rob K
RV-8 N884RA under construction
02-28-2014, 09:50 AM
Senior Curmudgeon
If it fails, will you die??
Will you continue to worry about it, if it is not replaced???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-28-2014, 09:51 AM
You have good access now and it's easily removable. If it were me I would remove and replace. If the rivet is a touch to short go with a longer rivet and file away some of the excess to be a X.5 rivet for a better shop head.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
02-28-2014, 04:43 PM
If the question is whether it's strong enough - it appears to be. Building on is certainly one path.
On the other hand, it will never be easier to fix. Even if it's a FUBAR in the attempt, the parts aren't really a big deal to replace. It's probably the way I'd go. There's a thread going on removing rivets - look that over, use a spring loaded center punch, a sharp drill bit, and a slow turning speed to get the head off.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
02-28-2014, 05:08 PM
I would build on with that one if it were my plane. And in fact I have a few of those scattered around for good measure on my plane?
It's about how much perfection are you striving for? I think any very small increase in strength by replacing it, is offset by the chance of making a mess while drilling it out.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
02-28-2014, 05:16 PM
If it is strong enough now - and it looks like it is - I would build on. You're more likely to mess up the hole by drilling it out than by living with an already-alright-but-not-quite-perfect rivet.
Somewhere in the manual I read that the strength of even badly deformed and/or cracked rivets were within something like 5% of the strongest "perfect" rivets. Unless you're building a gold lindy candidate or will forever be nagged by it, move on.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
02-28-2014, 06:03 PM
unacceptable
Having been a inspector on the Vought 747 production line I would not only rejected that rivet but would have chastised the person trying to pass it off.
43 13 shows proper (and improper) riveting.
02-28-2014, 06:13 PM
Tape
If are not using anything to protect the area, may I suggest a strip of black gorilla tape.
It looks like your well into the build so you probably already know. Just a thought.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Reason: change text
02-28-2014, 08:12 PM
+1 I would just replace it. There is a recent post on rivet removal that you might want to read. ( http://www.vansairforce.com/communit...0&postcount=17 ) I just drilled out several rivets today that would "pass" but looked crappy (a technical word). With practice, you can do that without any risk of hole damage. Rivet removal is a skill worth perfecting.
Some are in a place that can not be reached easily and are a super pain to get in and even more out. Those may be candidates for leaving. YMMV.
Bill
RV-7
Lord Kelvin:
Reason: added link
03-01-2014, 09:37 AM
Done!
Thanks for the advice. I drilled it out this morning and put a new one in its place. Scott's method of removing rivets made this a piece of cake.
Rob K
